I dont think there are any real cons to it. Just dont drill directly behind the paddles and you will be fine.
They dont work very well water crossing.
Unless someone can convince me that its way better then I'll most likely just keep my track stock.
The debate if it's better or worse is still on. For the last 5 years or so, new sleds were coming from the factory with big holes in the track. If you go look at new machines now, some still do and some don't.
The holes themselves will only save you a couple pounds.
In certain conditions, less snow will accumulate in the suspension, which will make it lighter.
I found the track rotates easier, so doesn't that free up HP.?
If you decide to do this, here's a few tips.
I did this with the suspension removed.
Make a wooden template to lay in between the paddles. use this to drill your pilot holes, 2-3 what ever you decide.
The template will keep the holes aligned.
Get a bigger piece of wood to lay inside the track.
Start drilling with the hole saw described above.
The hole saw will heat up and cut through the track like butter.
It will also cauterize the holes so no loose ends.
And do it in a good ventilated area, cause it makes a fair bit of smoke.
the track doesent loose a lot of weight but snow build up is almost goneMarkedly less snow stays in the suspension that's for sure. The weight savings are not even worth the time it takes to do it IMO.
and as you know 30 to 40 lbs is av min a skid..
