The " Blow Hole"
What defines "great success"?
ZERO issues with the running of the Blow Hole it's self- and while running other Pro's without the blow hole- belt temps would go up and seem to have the "hot" touch to the clutches themselves-
With the blow hole temps we reduced and continious running ( big pulls) tree running- the temps on the belt........ well..... clutches were never more than warm to the touch with a bare hand... Proving that the purchase worked with "Great Success"
With the high $$$ on belts this was a good and will do it again purchase.
S/C
S/C
Couldn't you have gotten the same result with good clutching and gained efficiency? That is what we did.
Yep- had good clutching that added to it.
Even with the good clutching on the other pro's my clutches were the coolest to the touch- and all were clutched the same/ except for one rider in our group that stayed stock (8,000-12,000 elevation) and his were the worst of the bunch as far as heat in the clutches- Oh and never had any type of venting on the Pro's- Hate cutting up a $12,000.00 sled.
Just MHO
S/C
Thats what a 340 HP turboed sled can do from Cat to a $250.00 belt-when not clutched properly.
S/C
i have always installed vent kits. had good luck, but still run hot. might try the blow hole this year. one of my riding buddys had one last year and had good luck, but the snow sucked .would it be a good idea to run both vents and the blow hole?
