The Best Enclosed Trailer for Hauling the 'biles
I am looking at a 2005 Hallmark Race Car Hauler.
26 feet, 7000 lb tandem axle, drop ramp door, two 4' side doors, lights, electrical connection for house or generator hookup.
I am thinking about building some bunks in the front, adding a propane heating system, getting a generator, building some lockers..Haul three/four sleds
Any thoughts out there on what the best enclosed trailers for this use is..show us some pics if you have the ideal trailer. Thanks ahead of time.
Check into 2 - 6volt batteries in SERIES. Probably 2-3 times better than 2 12 volts in parallel. Last longer times and you like better.
28' Aluminum enclosed. Fully insulated floors, walls, & ceiling. Webasto diesel heater. Aluminum tubing from the Webasto heater plumbed down the walls for each sled. Cabinets and shelves along the tops of the walls. Work bench & tool box in the nose.
This is how my buddies dad has there trailer set up. Sit on your sled and get dressed with the heater blowing on your back. Sleds are thawed out by the next day, gear is dry... Perfect!
