Thanks RK Tech! M8 Finally Runs....
J
JasonAK
Thanks RK Tek! M8 Finally Runs....
My M8 is finally making some real power. Low elevation Set up
Last years set up:
With the SLP pipe kit, BDX intake, Boyseen rage cage, 74.6 gram cat weights w/140/340 SLP primary spring, BD Box, 46/36P Helix and Cat Orange spring I could only pull 8150 Rpms at 1000FT. Sled had ok top end but the bottom end suffered. Never seamed to run right.
So this year I changed to:
RKT Porting, RKT Head 13:1, Stock y-pipe, Speedwerx 925 pipe, Super-Q can, Boyseen Rage Cage, BD Box, Stock Intake, 77 Gram Cat weights w/140/310 spring, 46/36P Helix and Cat orange spring, I pull 8200 Rpms at 1000ft. Sled flat rips, runs crisp and tight. No bogs or low end hesitation.
Jason
This is good to hear. Kelsey knows his stuff. Thanks for sharing your detailed setup with elevation and all.
This may be a stupid thing to ask....but isn't the sweet spot for the pre 2010 800 right around 7900 rpms? I know mine pulls way harder at 7900-7950 than it does at 81-8200....just curious
Your right..even maybe alittle lower around 7700 rpm....this changes when you start to modify. Most pipes for the M8 sweet spot is around 81-8200 which is were RKT sweet spot most likely is.
On 3 dyno runs, SLP pipe stock head max torque and HP were between 7800 and 7900 09 M8 SP
Is anyone running a slp pipe kit with a rk tech head and clutch kit on there m8? How's it running for you? I just put this set up on my sled. I have a 07 m8 and i know they ran a little richer, just wondering if its working and if you run a fuel box?
I'm running this set up but with some light porting on the cylinders. I bought it this way the previous owner has it dialed, it rips. Yes it has a boondocker box.
