TETHER SWITCH: MATING CONNECTOR FOR THE FACTORY HARNESS
5.00 star(s)
mountainhorse
Polaris uses a Delphi 56 series 2 position female connector for the tether switch hook-up in the wiring harness.
To connect to this, you will need the mate for that... that will fit securely.
If you are installing an aftermarket switch and want to have a clean way to hook it up..."Plug and play" then you will need the mating connector and terminals for that.
Once connected, give it a couple of stretch-wraps around with some good electrical tape for security and there you have it.
You will need to know how to crimp a wire terminal correctly... If you are not familiar with the proper way to do this... find someone that does... this is an important safety item that you do not want to risk a faulty crimp onto. ...Personally, for stuff like this... I like to crimp, Solder and use adhesive-lined shrink tube for the best in reliability
What you need is a Delphi 02977763-B housing ($0.055ea) and 12041129 terminals ($1.21 ea)
You can get them at
CLICK HERE FOR TERMINAL
CLICK HERE FOR HOUSING
FROM SNOWESTER "EASY"
attachment.php
1 housing... But, for good measure... order 3 terminals ($0.93 for 3) if you screw up (you need 2 terminals) ...
Man... I cant believe how much mileage were getting out of a thread about a connector....Cool!
BUMP...
Mouser shows plenty in stock for those shown in links in the first post of this thread.
Use the right connector and don't cut your harness.
Thanks MH for this info...I've been wanting a tether. Does anyone have a Polaris part number for their tether?
Just ordered 5 housings and 10 blades. Will be willing to send out 3 sets to anyone that wants em. Paid $11 for it all with shipping. Will do $5 shipped for each set. Should save someone a few dollars being that their base economy shipping was 4.99 alone.
Polaris Tether
#4010849 is the one I installed on my 2013 and 2015. The connections is in the black velco bag near the uper steering post bushing but I'll have to say it pushes in very had and not very far. Not like some of the other connectors that click into place.
