Tether install
donbrown
Where is the connection for a tether?
I bought this
[/URL][/IMG]
Is this the connector zip tied to the ignition key wiring ?
[/URL][/IMG]
I measured the 2 wire connector on the sled running and it has 16 volts?
IS this correct?
If correct why is it 16 volts?
I can't answer whether the voltage is correct but I just installed the exact same tether and used that connector. I had to make a short female-to-male lead using spade connectors but it works perfectly!
I understand from your PM that this has an engine swap.
2010 Chassis, carbed engine.
What sled is the wiring harness from?
Are the wire harness connections for a tether on 2007 IQ different from a 2010 harness? The connector is zip tied to the key ignition harness. Where are they for the 2007? 2010?
My Polaris tether plugged in right behind the ignition switch. It was plug and play with the wires provided.
