Seat removal? Not required, just drill hole slowly/ carefully with a stepper bit.Got er done this afternoon. The hardest part, which wasn't that hard, was determining how the seat came off.
Anyone install an Arctic Cat tether on a 2018 yet?
I just sifted through the directions and am planning to get into it later this week. It doesn't look complicated but we all know how AC directions can be sometimes...
Yep that’s what I figured. Is the new style. Only took a coupe of minutes to install. Most of the time it takes to install is taking everything off and putting it back on. Glad to see AC putting them on sleds now. It should be a standard part on every sled.
if your sled is factory compatable (cant remember if all 2018 models were) the wiring connection is right above the fuel pump. remove the right side panel and you should see the plug at the very top. if it doest have the plug from factory youll need the adaptor harnessHi, I just bought one of the new style magnetic tether switch. That I am trying to put on my 2018 ZR 8000. All it came with was the directions on where to put the tether on the sled. Theres no wire harness, nor could I find one to buy seprate. Also there are no directions on where/how to connect the switch to the electric on the sled. I have found info on older sleds, which doesnt help me. Any direction would be much appreciated. Thanks
