Tether install help
I bought an aftermarket Tether switch for my 2014 Pro-Ride chassis.
Is it as simple as splicing into the kill switch? Or does anyone know what plug under the handle bars to use that I splice into?
I thought I remember a topic on this before but I searched and didn't find any info.
Thanks
Not sure which tether you bought, but i installed a pro armour and it had the factory plug end installed on switch . There is a 2 wire plugin under hood in the main wire harness/velcro bag area. If you dont have the plug im sure just cut and splice the wires together, hope this helps.
Ya I found a topic on the tether install. I am just going to get some connectors and snap into the OEM plug, then cut the plug off the tether and install the wires into the male connectors.
