Completely stumped on a no spark issue, 2004 800HO DPM/RER setup. Been through the entire electrical system 20 times, every single component checks out per the manual. Pretty much leaves the MPEM, which to me makes no sense because the sled wasn't even being used- but such is my luck.
Proper verified power going in to the MPEM from the voltage regulator, but the primary power out wire (wh/bu) is dead. The only test I've been able to find for MPEM output verification shows that you should have 225-275VDC to the wh/bu wire going in to the ignition coil pack when pulling the engine over. I get nodda, although as soon as you stop pulling it over it does read up over 200v across the coil briefly and then bleeds off rapidly (must be some sort of capacitor inside the MPEM ?).
Continuity through the entire wire harness, DESS cord, DESS post, kill switch, relays, voltage regulator, trigger coil output, stator output, ignition coil resistance, et al tests right on the money. Don't have access to another MPEM, but to me that is the only variable left.
Freakin' been over every inch of this thing and about to put a quarter stick in the tank and walk away...
