Temporary repair for lower a arm, who has done this?
A
autowrench
I did try a search, came up with mostly info on re-gluing. Who has done a "temporary " rivet or bolt job to a lower a arm on a 13 or later Pro? How well did it work for you? I'm figuring on either aftermarket replacement lowers or a complete 36" kit, but I don't have the cash right now. Just need to get through the holidays and I'm not riding yet anyway. Thanks!
Tom
If you're arm comes apart on the mountain. Put in back in and use a good 1' ratchet strap. We use one last weekend for 120 miles and it was on problem. And a few times last year. When you're back home. Drill through the cast peace where the glue comes lose from and bolt it With a 1/4' bolt. 3 sled I ride with have done this and no problems.
Thanks! It's sitting in my garage. I have no idea when it happened in the last year. I wouldn't have found it if I hadn't been replacing ski bumpers with Ski Doo ones to head off another problem. Dealer says they have not successfully had one replaced under warranty. Polaris always finds a scratch or something. 4 year warranty is looking sketchy right now...
Tom
Well you have a ****ty dealer. I know of 11 that my friends have had come unglued and all were replaced that were under warranty.
Maybe so, but they've been good up until now. The only way I'm putting stock on is if it's free to me! Normally I would probably write it off but it seems like a poor design.
Tom
I did a patch repair on my 2013 to get a few rides in.
Rear tube had slid part way out of the ball joint casting, no bends or anything.
I carefully drilled a hole through the ball joint casting, being careful that it wouldn't interfere with the steering / suspension. I think it was a 7/16" bolt with a nylon nut, about 1.5" in from the end of the tube once seated fully. Held up fine for 200 miles until my replacement came in.
If I ever damage one on my 2015, I'm going to cheap out and get a set of timbersled SR lowers.
That's what I've been hoping to hear. Not a long term fix, just to get me through a short term while I figure it out. Timbersled looks promising all right. Thanks1
Tom
Did it. JB weld to replace Lords adhesive and a 5/16 bolt with nylock nut. Should get me through a few rides. With the thin snow around here, I'd be taking a chance with a new one right now. I need input on 36" front suspension. The Ski Doo XP Really needed the help. This sled rolls up so much easier, I'm not sure it's worth it.
Tom
