Anyone running the Tied with a turbo'd 800 2012 or 2013?
What helix and spring are you running? What elevation?
Thanks
Thanks
Depending on elevation. 59 straight or 61 straight with the spring for elevation.
The 58-62 doesn't hold rpm on the top like I like to see.
Glenn,
Eric set me up with a team tied 59 degree helix w a black white spring. Running the 12 PC with 7 lbs of boost. Love the setup. Through the trees in and out of throttle it snaps right back. I'm running 10500-11500 in elevation. Need a little more weight in the MDS weights. I was hitting 8500-8600. Running long bolt (hex head) with two washers in the tip. Nothing in the first hole.
