I'm looking for the facts on this clutch, is it the real deal? I ride a 2012 Pro RMK
and have been thinking of one.
Any ideas as to why Polaris hasnt made this standard issue? Its been out for several years and seems durable. Weight?
I have one on my 600 RMK and it is smoother,holds the rpm better(climbs better) and is better on steep downhills. But I lost the fun factor on the bottom it just wasn't near as snappy. That being said it could just be the helix, little too steep. They probably have the 800 dialed a lot better so I plan on trying it on my new 14 800 and going back to the stock team secondary on the 600. Not sure if this is any help but if I didn't already have it I wouldn't spend the money for the tied.![]()
I was in a similar boat, as I got a tied on a parts deal, ordered the recommended helix from TEAM and followed their set up and was under impressed. The recommended set up failed to improve upon the 04 set up I was using other than backshift and more constant RPM.
I set it on the shelf until one I was talking with IndyDan about clutch setups for a project sled. The discussion turned to the Tied and I told him I was not impressed with the performance of the clutch other than imprved backshift and what seemed to be more consistent RPM. We talked about the clutch and he said he was confident he could make it work far better than the intial Team set up. He had me send my clutch in and he did lord only knows what to it and replaced the Team helix with one of his custom cut units.
It is hands down the best money I have ever spent on clutching. The new helix made the Tied night and day better. Its way faster off the bottom end and it HAS top end. I havent been able to say that about Team clutches, ever. Belt temps are good and the thing is rock solid on RPM during climbs I dont think it changed more than 50 RPM from top to bottom.
If anyone has a Tied and is not impressed with the set up I would recommend contacting Dan and you can get some of the pixie dust he is sprinkling on these things... it flat out works. I now have 5 of them and LOVE them.
I have delt with Dan quite a bit over the years he is out in Minnesota, I have a tied also but not really seeing much benifit over the stock clutch so does he just do short track low elevation setups or does he have long track hi altitude setups as well?
I have spent quite a bit of time testing different setups on the tied. It does seem to hold rpm's better without falling off. I too started with the tied setup for 6k to 8k in elevation and improved on it quite a bit, but I have since moved away from it because it is definitely harder on belts. I have come to the conclusion that by keeping the rpm's up it seems to create more belt heat and more wear.
