Thunder, here's the real deal. Due to manufacturing "tolerances" there is NO blanket solution for this issue. Simply bolting on parts will NOT fix the issue. In my particular case, I stripped the sled down before I rode it and measured EVERYTHING, checked my belt alignment, parallelism, offset, and deflection. My sled's C to C measured 11 9/16", spec is 11.5". I had a good look at the new secondary design, and decided to do the following: I installed a Team Tied, using the provided alignment bar, with float sitting at .032". I bought vented panels from cat, installed polyurethane motor mounts, fabricated my own brake caliper / rotor splash shield, and installed EVO's BC250 kit, cold air intake, intercooler fan, charge tubes, boost recirculation valve, header & turbo blankets. I also added a 2.5" DP & MBRP muffler, all of which were covered in header wrap and sealed with silicone. Changed out the piece of sh*t belt guard, too. I rode the sled for 500 miles (all mountain in good snow, no 70 mph trail rides for me). All of my measurements are correct except my C to C, which explained why I had slight rubbing on the inside cogs of my belt. Since then I have changed engine oil, and replaced my belt with a Cat 084. It is the same compound, albeit slightly longer. It is my reasoning the belt is too short and bottoms in the pulley. I will be adding OSP's engine snubber and jackshaft support prior to my next ride, and hopefully EVO's 50 tooth bottom sprocket and heavy duty chain, too. This will allow me to save my $$$ to install a C3 belt drive in the off season. I'm of the personal opinion that the helix finish angle on the Team Tied is higher then it should be, and when one becomes available, I will likely be the guinea pig and test it. My primary setup is MDS weights with 90.26g, and a Polaris gold spring. I don't recall the helix or spring that is installed in the Tied, and I'm not home to disassemble it so I can inform you.
Fact of the matter is, I've not blown a belt yet. Maybe it will be my turn the next ride out, but I've seen no appreciable wear on the belt I just took off...
And as far as me being "selfish", you don't know me very well - I'm the first guy to stop and help someone on the hill or answer a question, but disclosing the contents of someone's clutch kit, porting specs, etc. is not cool, especially when the vendors spend countless hours to improve upon a product. I actually think they should be paid for their efforts. Do you work for free? I certainly don't...
