Team Primary clutch
Darryl Atkin
New member
What would be the difference between 2019 and 2016 artic cat m8000 team primary clutch.Need new onw and looking for options.
I went through 6 team clutches on my 2019 Alpha. All covered under warranty (4 year) I then put a adapt clutch on it and so far no issues. I have a little over 4k miles on the sled.
2010-2024 crank taper is the same on the 800s. All clutches will bolt on, need to match the belt to the sled clutch combo.
The 2018+ roller clutch with the 111 belt, fits 2012-2024 800s.
Amazing performance, just make sure to thoroughly inspect clutch after every ride for cracks cause they will explode. U should be safe for at least 500mi and up to 3,000mi.
Sent from my SM-G998U using Tapatalk
