TEAM clutch of a 2011 M8?
B
Dec 14, 2010
179
13
18
29
Looking at a 2011 M8 with 1800 miles. Owner says he replaced the primary with a team rapid response (can’t remember why he said he replaced it). Any concerns with these team clutches on a 2011?
In a side note, owner also said when the sled is laid over on its side, the side plastic will push in enough to allow the secondary to rub on the plastic. Said that was normal. Can you guys confirm?
boondocker97
4,101
2,842
Billings MT
Yep normal to rub laid on its side. I wouldn't worry about that Team primary as long as it doesn't have the roller bearing in the bottom.
boondocker97
4,101
2,842
Billings MT
Not too familiar with the roller bearing you are talking about, do you have any info/pics handy on it?
It's a big roller bearing that sits down in the bottom valley of the clutch where the belt sits at idle. Lets the belt run tight with no deflection, but the roller will let the clutch spin inside the belt without burning it. It looks like this: https://www.countrycat.com/oem-arct...-0746-895-clutch-dr-uncal-team-hdi33mm-423460
No roller is what you want on that sled like this model: https://www.countrycat.com/arctic-c...tries-rapid-response-drive-clutch-8-inch-33mm
They look identical except right down in the valley where the belt sits. Note the larger diameter shaft on that first link.
