te300 turbo questions
simbatheking
I just got a te 300 and then got thinking about putting a track on it, then got thinking about a turbo. ive built my turbo summit carb w great success. my questions are
-are there any other light small self lube turbos other than aero 53? aero has a bad rep for reliability and pricey.
-has anyone else turboed a carb bike? if so did u need another carb for summer use? how did u set up ur carb?
I think I could figure out the rest
After researching on my cr500 blown crank seals and issues with crank bearings seem to be a real sticking point... I am pretty sure I am going the 20 shot of nitrous route next year... Most of the time I have plenty of power but I want an eject button for hill climbs and extending a needed gear...
Sent from my XT1585 using Tapatalk
Also I would ride it first before modifying...
what size turbos are guys using and what comes on the kits? the aero 53 has about 10 different variations. what size are kms and boondocker using? Id like to run at least 10psi on a te300
Boondocker uses a gt2052 turbo. The rear mount kms uses a Gt2056 the front mount kms uses a gt2252. There is also a company that also makes oil less turbos called compturbos there is also KPa oil less turbos also
