Are you sure the brake light was working prior to installing a LED light? Dont forget the brake light switch on the handlebars. Check the voltage on the Orange wire when you pull the brake. If you do not have or know how to use a volt meter (they are easy) you can use a light bulb circuit tester that you can get in any RV store or most automotive stores. It will be fine for checking brake and light voltages..you just hook up the graound and then stick the wire or connector and the tool will light up. Verify that you are getting the voltage on the orange wire first.I have wired a l.e.d. brake llight on a 2007 600 ho carbed, but only the tail light works no brake light. What is the fix for this?
