Tail light mod
Maybe it will work for you, make sure your track wont grab it
Use the stock mount but flip the light over and screw it back onto the base
Cutting the hole is a leap of faith, put masking tape on the face of the light and cut around it carefully with an exacto blade, put the tape on the tunnel as a template, the top side need's to be flush with the top of the tunnel, I traced it with a felt pen and then peeled the tape off
Cut 80% of the hole with your cheep dremel knock off, it will burst into flames at this point, cut the rest with an airsaw
make the hole a little small and file to fit, you need to extend the wire and find a way to keep it out of the track
ha ha... nice! I did close to the same thing, except I omitted the black mounting plastic and just used the two screws for the light itself mounting the whole unit on the outside. I ended up using the rubber grommet things so that it is a little flexible too..
Nice work! Too bad it cost you a tool, though, now you have a reason to get a new one!
