Here is a little trick for those using ramps and SkiDoo Summits. The tail flap gets caught under the track as we back off our ramps; the easy solution was to cut about 3" off (right where BRP has a line across the bottom part) but then there was a problem with cooling.
This little trick solves all of that and works with the XP and the XM sleds. I assume it will also work with the new T3 whether it be a 163 or a 174.
