I just finished installing a set of the T-Rex A-Arms on my '23 Khaos 850. I tagged a rock a couple of rides ago with the right ski/knuckle and tweaked the right upper A-Arm. After a lot of research and reading the other big T-Rex thread here, I decided to give them a try.
Installation is fairly straightforward except that T-Rex's idea of instructions is an absolute JOKE. At least there was ONE useful tidbit, and that was to seat lower A-arm heim joints in all the way and then turn them out three full turns. A piece of info that WOULD have been helpful is if they'd mentioned that the gusseting on the uppers should be facing upward. If not, they will contact the shock spring at full droop. I noticed this after installing them the other way. At least swapping uppers is super quick 'n easy.
I haven't ridden with them yet; that happens tomorrow. I have one extra set of joints and two extra bolts for the uppers, and the tools to do a field repair. Let's hope that isn't necessary for a long time (ideally never).
Now here's what's odd. I took my old arms and compared them to one another and they do not appear to be bent at all. The bulkhead appears totally fine and the new arms installed without issue and everything appears to line up and is even side-to-side. Go figure. Maybe I have a complete extra set of arms now. Or I could sell them I guess.
The T-Rex arms are slightly heavier than stock... just slightly. i didn't try to weigh them. They aren't nearly as pretty either, but if they hold up better, I don't care.
