T
TheBreeze
I am trying to diagnose a strange cut out/bog that has developed on my sled.
I have not pulled the reeds yet to have a look....
However, I thought I could feel some warm air coming from the expansion chamber on my pipe that is wrapped. I don't want to cut off the wrap to have a look.
I did pressure test the system with a cold pipe, and found no leak in the suspect area. Is it possible that a split pipe would only leak when warm? If it was leaking, even when wrapped would there be visible evidence of the leak under the hood? What run ability issues do people experience with a split pipe?
I don't have any boost leaks on the cold side, and the hot side seems tight when tested cold to 10 psi.
Nothing on my setup has changed, but my sled cut's out at slow speeds just prior to, or as boost comes on, but once in boost runs great. The cut out is intermittent, and easily ridden around, but still suspect IMO.
