switching from noh to rpm
I can get the second line to switch but can't figure out how to get the big numbers to switch from mph to rpm. Anybody know how?
i forget....think it needs to be mph in the big and rpm in the small and your hold mode or set and it should flip them.
i have mine large numbers rpm and small temp.... so its doable.
This can drive a guy crazy, so once I found my setting I leave it alone, Big RPM and small temp.
The big numbers are for SPEED, either engine or vehicle.
Press and HOLD the "mode" button for 3 seconds.
The smaller area is for info, rpm or vehicle speed (which ever is not in the big display). Also eng temp, max speed. To change these, press and RELEASE the mode button until you find the one you want.
