switchback fst
a harness can be made so you can plug any obd2 automotive scanner into your fst to read and clear codes. It will also allow you to data log depending on the device. I make and supply them to a company called precisionsports however i sell the harness individually. Not saying you should buy one from me, the sled end of the harness is a P4 ATX computer plug and the scan tool end is off any obd2 car, if you are handy you can make it. Does that make any sense?
i'm can handle the wiring no problem if you would be interested in suppling a diagram otherwise what do you get for one. It suck we're a 100 miles from a dealer and a sick sled
a little hose come off by the turbo that goes to the boost relief on the compressor side we put it back on but now the check engine light is on and it must be in the detuned mode it pops when you get on it now we think it just needs a code cleared
kill switch down, turn the key "wake up mode" then pull the efi fuse. I think that clears the code manually. Search on polarisfiles.com tons of info there
4 people 3 small allen wrenchs 3 jumper wires and mac tools code readers and it cleared the boost code machine runs great thanks for the help its saved a 100 mile trip to the dealer and who know hows much at the dealer thanks big time!!!!!! these forums are great
