Sway bar help.
Bought my 07 Dragon with a snapped sway bar so I just pulled the thing out. With my stock WE shocks it is incredibly mushy on the trails but I really like the carving ability in powder. I can't afford to put Fox floats or another shock on it. I found a guy not far from me parting out an 05 Polaris fusion 900. Curious if the sway bar would fit on my sled. Part numbers on Polaris parts house are pretty close to the same. Only a few numbers different. Will putting one back in drastically change how it handles? Also how hard is it going to be to put it back in. Any tricks. Haven't really looked yet but just curious. Any help works. Thanks all.
did get it in , take the bottom rt shock bolt out , take both the lower rear trailing arm nuts off , I cut the bushing for the sway bar on the rt side off from the sled , with the sway bar facing the frt it can be forced in , have a budy on the left side guide it through, this is when you pull out the hammer , it will go in , it's tough but got in , good luck
