suspension setup
mountain man
I have a 11 Nytro stock 162 skid and a skinz concept front suspension with fox evols on the front. Wondering what everyone is running for setups. Sled seems really nose heavy and steers horrible.
Thanks Chris
Sounds like your rear skid may be set up wrong. Where is it mounted, how tight is your center shock? Where are you limiter straps?
Settings
The rear suspension is in the upper mount hole, the front limiter straps are all the way out and the rear strap is also all the way out. The front skid shock has around 100 LBS air and the rear skid shock has 135 LBS in it. The evols up front both have 100 LBS in them. Maybe i am completly off. Someone else chime in and let me know what they are running. Yes i know the i need a different rear suspension but cant afford one right now.
