suspension setup
I just ordered a set of fox float 2s since i had a bent shock on my sled what im wondering is does anybody have any recomendations for a good baseline air pressure in these shocks... also whats the consensus on removing the sway bar on the 05 900 166track.. i was also considering the timbersled rear suspension setup how noticible was the change in handling... one more thing 4 now ive read multiple times about the steering position delete and was wondering were i could buy one of these setups thanks for any info you can give
Timbersled rear skid makes a huge difference in the ride and handling. Sled floats over everything and is not affected nearly as much when you cut a track while climbing. Plus it will drop around 16 to 20 lbs of your sled.
PM Polzinhunter for rider select delete. http://www.snowestonline.com/forum/member.php?u=44059
attachment.php
