M
mtn-doo
The new Piston driven Rave Valve from Supreme Tool is finishing testing. They will begin production shortly. They are an all aluminum cylinder with an internal piston that is screwed on the Rave Valve shaft. An internal pressure port accesses the inside of the cylinder below the piston and pushes the piston "up" to open the valves. They are 100% boost proof. No bellows or springs etc. to fail under boost. They also do not require bleeding any pressure from your system which gives you the quick spool-up and throttle response you need.
I have been testing them for Supreme Tool for a month now on my Turbo Performance XP with the Garrett 2871 turbocharger and 12 to 14 lbs boost, with tremendous results. Give Mark a call at Supreme Tool, or feel free to shoot me any of your questions. Thanks
