SnoPro753
I installed my STM Valves on my M7 tonight and I have a few questions for those who have also done this.
Did you have very tight clearance between the valve and the radiator hose on top of the head? If so, any long term/high use problems with the two contacting each other?
When assembling the valves I installed the popup indicator pin with a spring on it? Is this correct?
When I installed the valve itself I put the 1/8 inch gap of the valve pointed down toward the crank, meaning larger beveled edge of valve facing the crank. Is this correct?
I currently have my secondary off the sled for other parts install and I started the sled up with the new valves and gave it some throttle. I saw the popup pin move but only ever so slightly. With the secondary installed and a load on the engine will the popup pin come out of the assembly more?
Any tips on dialing in the valves?
Thanks to Snowest in advance.
