SNOW JW
Below is what you get will sell for $210 shipped
Yamaha X Series Cam Arms
Yamaha large pin-$270.00 per set
New improved profile that provides a harder up shift than the Original Supertips. We are very pleased with testing results on the race track and chassis dyno this past season. We found faster ETS along with an added +3hp to the track during dyno tuning. An excellent choice for drag racing or aggressive trail riding.
Available in 55 base arm with the capability of adding 42 grams per arm for adjustment. This design allows the option of adding large quantity of weight to three different areas on both sides of the cam arm to create the shifting characteristics you desire. Each arm is supplied with tungsten and steel washers that can be used in various combinations to achieve the desired operating RPM. The Supertips will fit the 8mm diameter pin in the Yamaha primary. The 60YX is a new option for the RX1- APEX turbo sleds. Our tungsten washers weigh 7 grams each. There is no other arm on the market that allows this wide range of adjustment. The Supertips are a drop in piece that requires no modifications to your primary.
Each arm comes with the following hardware kit:
Tungsten Inserts - 7 grams (6 qty)
Washers - 1 gram (54 qty)
O-rings (12 qty)
M3 x 6 screws (18 qty)
M3 x 7.5 screws (18 qty)
O-rings (12 qty)
