Super chute questions
psychosledder73
Lookin at buying a super chute setup right away. Anyone using this setup to the full potential of the claimed 350hp in the mountains? Will the programming allow auto comensation if using higrade race fuel to advance the ignition and increased boost levels to reach this via the factory oxy sensor?
Also heard some talk on using a longer belt with this setup. Will be upgrading the secondary to a team tied setup.
There are many Super Chutes on the snow. They are VERY strong. We have limited the kits for the masses at 300 hp. The reason is at this power level, this is the upper limit of the stock engine internals and fuel injectors. Power beyond this level requires pistons, connecting rods, bottom end studs, etc, fuel system upgrades and a map sensor upgrade. If you want to go beyond 300, we can accommodate you, but it is a little more involved.
Our programming adapts to fuel quality by adding or subtracting timing to a point. The boost is self compensating for altitude. With respect to the narrow band lambda sensor, at WOT it is open loop - in other words, it does not reference the narrow band. The factory programming operates in the same manner with respect to the narrow band.
Seeing as I am the only built motor in a PC 1100 chassis.....
That i know of on an m series. I will be more than happy to test ride the 350+ SC kit. Hell I'd be happy riding a 215 flash it this point.
I just got another 6 team clutches in. My understanding is they don't have anymore for the season. So get them while they are hot.
Also got the prototype Gates Evo got made that is longer that the stocker. Testing that next week in Wyoming if all goings well.
Been running the Superchute all season. If "too much" is "just right" you will like it a lot!!!
