Summit idle question
I know it is probably easy to adjust but not sure how to do it. I have an 06 Summit 800 X. After you start it and it is warm the idle drops down to where it should be 1200-1500 (is that where it should be?). But after riding it the idle stays way too high 2500-3500. At times the clutch feels like it is almost engaging. Just wondering where the adjustment for the idle is located. Thanks.
There is a knob on top of the carbs you turn with your hand to set the throttle. If you install 20 pilot jets it will get rid of that inconsistant idle problem.
Ditto on the Pilots. You can richen the idle mixture some also, white knob on lower right side of carb.
