Summit 800 spark plug caps
Probably the cap tips are shortingn out inside... they coil around the spark plug tip can crack off and then arc to the remainder of the wire, change the wires with NGK race wires, be careful at the coil end with the little plastic clip
Also check the clearance to the hood as they may also be rubbing a little,
Are you talking about the foam? that seems to be the only thing above the caps. I just put some new caps and plugs on and it is still happening, so it is probably rubbing something.
