I got my first sleds this season: two m-series, a 06 m7 and a 07 m8, both in their “mid-life crisis”. The M8 got 5000km and the m7 4000km. Here is the maintenance list I’d like to do. I am pretty new to sled mechanics so I am reading thoroughly the service manual and searching all the forums but since nothing beat first-hand experience, I have questions for you guys:
( i m trying to dump all of them in the same thread rather than making different thread... Since this thing is likely to get messy, I ll try to make a cleaner document at the end of the exercise summarizing what I did/learned)
- Engine:
[FONT="]o [/FONT] I seized the M7 on my last ride. Not really sure why. After a hard pull (going up an icefield WOT in heavy slush) we stopped at the top for perhaps 10mn or so. It was rather warm outside (+5C). We then proceed to go back down. I was reving around 7krpm when after 1 or 2 mn max the motor shut down. The recoil was seized. We were able to spin the engine couple time actuating on the clutch itself. We then tow the sled back to the logging road. There I was able to restart it and ride back the 25km. As of today the recoil feel “tight” but the engine start. Upon inspection of the left cylinder through the exhaust port there is some scratching but hopefully not too deep. Compression test is 95 in the scratched cylinder, 105 in the other one.
§ Question 1: Why did I seize? Could it be the cold rush of coolant? I restarted too hard without enough warm up? Did I went too lean (hence coolant pump is dead)?
§ Question 2: I am going to put new pistons/rings but I wonder after the cylinder. I am short on cash and replating is like 300$. I read in few motorbike forum guys only refinishing the cylinder with a 3M scotch brite pad., lots of debate about flex-hone tools and other polishing tools. What’s the consensus here?
[FONT="]o [/FONT]While I am at it, should I rebuild the M8 as well? As of last ride it was pulling strong I haven t done the compression test on it yet.
[FONT="]o [/FONT]Clean air filters
[FONT="]o [/FONT]Clean spark plugs
[FONT="]o [/FONT]Empty gas tank
- Chassis:
[FONT="]o [/FONT]Clean thoroughly
[FONT="]o [/FONT]On one ride this winter I broke the steering column on the M7 and replace it. I am going to go through both chassis to find potential cracks. Is anybody has a check list of the classical failure spots? My A-arms are slightly bent on both sleds. Are those indestructible or should I plan on installing new ones?
[FONT="]o [/FONT]Re-grease all the pivot on the suspension
[FONT="]o [/FONT]Add grid to side panels for better clutch cooling
[FONT="]o [/FONT]More zip ties to the M7 hood/panels (or is somebody got a very cheap replacement?)
[FONT="]o [/FONT]Re-tension the track properly
[FONT="]o [/FONT]Is there some particular bearings I should look after?
[FONT="]o [/FONT]Set-up suspensions (damping/springs)
- Clutch/brake
[FONT="]o [/FONT]Change the oil of the diamond drive
[FONT="]o [/FONT]Clean thoroughly for dust and leftover belt pieces (I blew one hard last ride :S)
[FONT="]o [/FONT]How to check that the clutch is in good shape? Are some bearings prone to break?
[FONT="]o [/FONT]Anything special to check on the brakes?
- Electrical/pumps
[FONT="]o [/FONT]I don’t have any engine light on, which is good, but is there anything else I should look after?
[FONT="]o [/FONT]How to check the oil pump?
[FONT="]o [/FONT]How to check the coolant pump?
[FONT="]o [/FONT]How to check the gas pump?
[FONT="]Am I forgetting anything else obvious?[/FONT]
- Engine:
- Chassis:
- Clutch/brake
- Electrical/pumps
