ok. I have a 2000 gen II 800. motor done by curt at fastrax. drag racing the sled. the problem is cant get over 73.5 miles an hour in 500ft. It gets there extremely quick, but towards the end of the run its like it levels out and quits pulling hard.
If you are quarter inch from top of primary that sounds pretty good to me. Are the rpm's falling off at the end as it quits pulling? If not I would throw some more helix at it or soften the secondary spring. This will also pull down the belt in the primary a little. This may balance out the clutches some. If you're are tuning to only 500' you may need some kind of timing system to really know what's helping or run along side another sled at least. Check your piston wash at the end of each pass. Also, make one change at a time so you know which helped.
Thanks for all the suggestions. Was thinking that a lighter primary spring and more weight, engageing now at 6000 rpms. lighter spring would bring down the engagment right still learning all this fun stuff. Is the heel clicker clutch set ups worth the money.
If i remember right the secondary spring is gray and black. What helix and spring do you recomend
