Read in the post that someone got stuck with is pro in a ravine with a blown engine and it was quite hard to get out.
The best way to get it out is to winch it.
And a sled is a 150-160HP winch. The track is the winch.
Situation A : you're sled is still working and the slope is too steep.
Just lay your sled on the side,attach a short rope across the track in the 2 track window and attach a long rope to that short rope(in the middle,when you are going to winch the rope will stay in the middle of the track).Then attach the long rope to a tree in the up slope ,put the sled on his track ,point it to the top of the slope,start the engine and winch. When you get to the tree (if you are not at the top of the ravine).just put the sled on his side ,unroll the rope,and repeat till you get to the top.
Situation B : you're engine is blown (must be another sled)
The winch is now the sled at the top. Attach the top sled bumper to a tree or another sled. Pull the top sled on his side and make the same attachment of rope as per situation A ,Attach the end of the rope to the stuck sled (make sure to get the belt off). Then the top sled start is engine and pull the stuck sled.
Make sure that you always have a long rope when you go backcountry..
N.B. We got a f-7 from a 150 feet ravine with a 60e steep grade and that in just 1 hour with a 60 feet rope. To do that ,we were 4 sledders . One was on the trigger,one on the brake, 2 at the back keeping the sled from going down when each one had to make a step up to follow the winched sled.
Hope that this thread can help some
