Stubborn Flywheel wont come off...any ideas?
I've go the same problem, my uncle said he just took 1/4 piece of steel and made a template and used that to get it started then it just pulled right off. I'm going to try it tommarow on mine.
pulling flywheel
the most important thing when pulling the flywheel is to have the puller as perfectly straight as you can (very important), then snug it up and tap on it with a hammer.If its not straight they come off very hard sometimes.
tough flywheel
everything Stew said was right. If she still wont budge, get a NICE new puller. Next go get some beefy bolts for it. I think mine were schedule 8. Now get a 2 or 3 foot piece of pipe for a breaker bar. Might seem a bit much, but it will come off. Give 'er hell, and it'll pop. Have fun, good luck!
D
These are things I have done to get them to come off.
Do as others say and get a good puller lined up straight and snugged up good and tight. Wack the puller straight on with a good heavy hammer. If you use a heavy hammer you don't have to swing it hard, but it will have a bunch of force behind it.
If that doesn't work, then take a torch, propane or gas just be careful because there are electrics behind the flywheel. Heat the fly wheel down by the crank shaft. Get it good and hot, so you can't really touch it with your had.
Check the tightness of the puller again. Now take an icecube and put it on the crank shaft end. You are trying to cool the crank shaft while the flywheel stays hot.
Another thing you can do is to do the above then take a brass drift and wack the face of the flywheel to shock it.
The final thing, if none of that works, is to put the puller on it good and tight and let it sit under tension for a day. Maybe even a couple of days. As it goes through warming and cooling cycles in the garage it will pop off.
I've always been able to get them off doing those things.
sled_guy
also make sure the puller threads are clean and lubricated - I pulled the flywheel on my xcr last week and it came off very smoothly with moly on the puller threads.
Def, get a good puller. My buddy had the same prob. with his xlt. He ended up gettin a new puller and it came, but it was still a pain. Def. some antisieze will help on the threads.
