Strange starting situation???
I have a boondocker turbo that is and has been finicky starting.
I have replaced the relay.
It always clicks in the relay but it does not always turn the motor over.
Here is the strange thing: If I lift up on the inner-cooler it turns over every time.
I have had this problem off and on for the last three seasons.
What do you think????
Sounds like a poor ground? Or a short?
You may be right.
We have added what we think is a better ground.
If it is a short it must be after the relay.
The problem is very inconsistent. I have gone months without it and then had it happen several times in a day.
or
Could be a poor connector on the relay. I would suggest unpluging it and use a air compressor to blow the plugins dry and use some dielectric grease on it to keep moisture out. I would reccomend that on all connectors.
Same problem!
jUST STARTED HAVING THE SAME PROBLEM AFTER HAVING THE BATTRY OUT FOR THE SUMMER. GOING TO CHECK ALL CONNECTIONS AND GROUND! IF U FIND ANYTHING OUT LET ME KNOW.
BigDOGG yours sounds like it could be a battery issue. Pastor Also might have a bad cell in the battery. Has it been the same battery all the time? Does it make a difference if you jump start it?
