You all were so helpful in diagnosing my last tough issue I thought I'd try again...
I just replaced an oil seal so had the motor all the way out. Put it back in and took it for a test ride on our lake, it ran ok but at 3/4 throttle it felt like the cylinders were not working together, or maybe it was running on 1, great low end... loads of power until about 3/4 throttle then just maintain speed running boggy... If I feathered the throttle it would 1 out of 6 times wind out fine and have top end power too. This was flat out on a lake.
Took it up a trail at 6 degrees and it started having no power at all, 15 mph max... temp was reading 120s... running boards were barely warm. If I turned it off for 5 mins and started again temp read 160 all the power I wanted for about 1 minute then more of the same boggyness. Limped back to the lake toward home got on the lake and it sputtered along at 15 mph then it cleaned up and went full power all the way home.
If I let it sit and idle the temp climbs into the 180s, as soon as I move it drops within a minute to 120s
I'm confused... stuck thermostat? busted water pump? The running at 120 degrees, would that cause it to run so bad? Doesn't seem so... Does the top end bog out relate to the other bigger problem...
I'm new to the sled and am learning a lot about it fast... Thanks for any ideas.
