storm 800 into xcr 600 chassis
3
340rotaxrider
New member
Is there a painless method of mounting the 94 800 motor into a 95 xcr 600? This swap needs to happen. Thanks for any info.
Motor
Measure the motor strap mounts in the bulk head. If they are in the same location on both sleds then it should bolt right in. If not your best bet is a solid plate from PSI1200. In using that plate, you will need to drill it for the storm motor. If you still have the 94 chassis you can use it for some critical measurements. Pull the air box brackets, pipe brackets, and oil bottle bracket from the storm. If you use the storm oil bottle, you may run into a clearance issue on the gas tank. You can either use the storm/ultra seat tank combo or come up with a different oil bottle. Space is kind of limited because of the 3 carbs and air box. Be sure to set the motor half an inch to the left like the storm so you will have room for pipes. There is a spacer under the driven clutch that you will need too.
PM me if you want more info.
Gary
