I have spend hours trying to solve my belt blowing problem with my 2012 high country xf1100 TD turbo. I have done the OSP engine snubber, jackshaft snubber, heavy duty jackshaft and perfect alignment/parallelism.
as per TD suggestion:
primary spring: dalton red silver 185/300lb
weights:dalton 6wl @93g (to hold at 8250 on powertrail tune)
dalton spider shim
Helix:46/38 then back to 42/40
secondary spring: did have stock blue (175/185lb).... went to dalton green gold (185/320lb) thinking the secondary might be slipping?!?!
cats upgraded big fin secondary with properly cut spacer
XTX5020 belt
entirely vented side panel with frog skins all around, silicone'd up all cracks that could allow snow in.
stock 95mph high country gearing 22/48 changed to gearing out of a 2012 m1100t 21/49
The clutches on the sled run cool to the touch in the trails even agressive 70 mph corner to corner (they did not before the OSP alignment/paralellism)
10 mile long 80mph lake run on hardpack...... still cool clutches.....
Problem: clutches get extremely hot and blow belt into a million little pieces or snap right in half within less than 10 miles of off trail riding in the deep snow, on and off the gas alot powder carving etc, seems like the secondary gets hotter than the primary. I have to get this problem fixed the sled is useless to me like this..... blew 14 belts in 850 miles...... would really like to go on a ride to bc but that is out of the question with this machine it cant even handle powder in Ontario!
What are the mountain guys doing to make belts live boondocking or does no one ride them aggressively in the mountains?
Can anyone see any problems with my clutching combination?
Any help would be greatly appreciated
dalton spider shim
XTX5020 belt
