Steel drive shaft
A
284
Alaska
Yes you can use the steel driveshaft from the assaults. The only difference if I remember correctly is you need a shorter bolt for the bottom pulley on the quickdrive because the end isnt tapped as deep for some reason.
I run this and Avid anti ratchets on my 2021 khaos and the ratcheting is long gone. Still vibrates though.
Given the current Polaris issues I wouldn't wait around for their "fix"
kylant
1,672
396
83
CA
get a steel driveshaft from an RMK that has the 3" track. press on a set of extrovert drivers, trim rails, anti-stab kit. done
that's what I have done.
