Thiis is my sons sled and I am totally stumped with this electrical problem and in dire need of some help here. This is what I have done and tested so far.
DC output from Regulator disconnected
Battery connected to the chassis wiring I get lights and all works and unit starts. When running like this I get 0 DC voltage at regulator output
When I check for AC voltage at the stator wires with regulator connected I get no voltage when I check it with the regulator disconnected I get 15 to 45VAC on all 3 stator wires to ground and double that between the yellow wires. Stator resistances all test as per manual. I bought a new regulator (jobber one for $40) and get same results. Is it possible to get a new bad voltage regulator? Could it be a stator that cant carry the current? I hate to spend more money on things that don’t fix this thing.
Does anybody near Saskatoon have a regulator I could try and then buy if that is my problem?
Oh I have checked all the wiring had the stator out twice looking for rubbed wires (had that problem last year)
Checked hood wiring connections and all is good like I say everything works when I connect a battery to it so the wiring is OK.
