Stator and flywheel shot..what are my best options?
Just found out the stator is ungluing and needs replacement and the flywheel is starting to look like it need replacement also.
What is the best option for this issue..suck it up and pay for new original one or is there a new year or model that will fit or cheaper replacement through aftermarket?
Looking for options to get this fixed best possible on a budget.
Thanks
If your flywheel is simply comig apart then I would recommend using a good 2-part epoxy to glue it back together and it will be better than new (I've done this to at least 5 900's). If there is physical damage then I would go used for the flywheel (then try separate it and epoxy it) as a new OEM replacement will cost you a new born.
Wrt the stator, the price difference between used, rebuilt and new wasn't significant so I went with a new one from polarispartspitstop.
Not sure if I like RMStator anymore.
Had 2 rebuilt staters from them and both have failed within 1 season so far...will not use them again.
I wonder about dragon flywheels on the 900s but I have never seen them side by side, so no idea there. I know the 06 models came with updated epoxy, so I would just stay away from an 05 used model
Flywheel
Assemblies where 4012589 is used
