I don't know if its necessary. All a know if after 400 miles mine stock reeds started to crack so i got TDR reeds from mountain magic and cut my stock ones and stacked them behind the tdr. I now have 1200 miles and no problems and i was running 10 to 14 lbs of boost
why does everyone say they cut their stock reeds? i just stacked 2 sets of stock m8 reeds togther but i couldent see any need to cut anything?
They were about 100 bucks with shipping. I cut them so it doesn't slow my throttle response anymore. but still gives you more support when your in and out of throttle. since on boost you have some lag already
I accually found that if you just stack them and dont cut them it works better.
Good to see that Boyesen is listing their turbo setup. I got a set from them at end of season to try out but they didn't get them out before we lost all snow. Nice looking setup with complete rad valve assembly. Uses dual stage with fiberglass first stage and carbon fiber second stage. The carbon ones are much thicker than what v-force uses and look like they will stand up better than glass ones. BTW the TDR reeds are no better (not saying they are worse either) than stock M1000 reeds. Stacking old chipped ones on top of new does work though. Using 1000 reeds on M8 works great and is something I do on all M8 turbos I install. So far no failures of those on an M8 on the ones we did here.
