Anyone have any real world input on this set up? It looks promising without a fuel controller....
Sent from my ONEPLUS A5000 using Tapatalk
I was thinking timing key, mod pipe and y pipe. If it works as advised that's a pretty easy 10 hp....That is great information. Beyond that I am personally curious about just running a timing key vs the head to save some money and possibly maintain warranty. and the other question is have other people ran these setups at lower elevations? He is at about 9k feet it sounds like and although he makes reference to knowing someone riding at lower elevation it would be nice to hear from actual experienced customers. My setup needs to be reliable from about 1500 to 11k.
I really like dynoport's videos on y pipe dyno numbers.
Wouldn’t any power increase need to see weight increase in clutching? If runs same rpm I would say not much changed.Pipe mod and can in mine and no problems, 260 miles. Runs about the same imo just the pipe mod I dont think made power but the weight loss is more important to me. Might try the y pipe but I was nervous that would be bordering on needing a controller with the stuff I have. It is crisp and clean on the throttle at any position, trail or powder. There is no bog at all!
Break in was about 110 miles so I was easy on it and then installed the pipe and can, started riding harder after that. I should say the rolling speed and hammering down feels stronger so the mid range May have the best gains, top end I think is limited by the track and gearing...
165" rider dressed about 200lbs.
Yep my highest rpm was 8200 and that wasn't hardly done within breaking in miles. I think I hit full throttle twice in 100 miles. After 100 I'm consistently running 8150 to 8200 rpm. Just the pipe mod alone didn't add much power overall, can feel a stronger mid range thump tho. Also at 9-11000 feet. May be different lower?
