does a srx and a MM have the same driveshaft. length and diamater. Thanks Andy
Yes but you want 01 or newer driveshaft, much stronger
You can tell by the speedo end
It has a small 90 degree cut in the shaft end instead of a small taper
I've always been told that, but ran thousands of miles on a '00 and had a new '01 shaft with me at all times and never had a problem. (Ekholm D&R tunnel with 9T extroverts)
It's actually not a weak shaft, the suspension tensions the track when it travels, if you have extro's and have some hanging slack you probably would never break one
