Squish on M8 turbo
Squish
I am actually working on a Bikeman 700 to 800 bored engine with a garrett and the squish was about 62 so I had it milled anther 10 but it turned out to be about 75 when I put it together and checked it. I ran it today and it seemed to work very well at about 3000' 10-12LBS 100LL. We didn't make it to 6 or 7 or get to make any climbs due to reed failure on the M12T.
Thanks for the input.
squish...
.075" will be good with high boost pressure to help control detonation, backlash is you might loose 2% on bottom end throttle response.
It is always best to machine the domes. Base gasket thickness will raise the port timing, which on naturally aspirated may not be a bad thing...but on the turbos, I like the stock or even a pinch lower on the port timing.
A thicker base gasket will open up your port timing, not the way to set up engine for a turbo. Mill the cylinder base and cut the squish band, open the dome for high boost or cheep fuel. JMO
Opps The Racestation beet me to the post, faster than me.
