sledneck_03
I know what the book specs for my weight but what did you guys mid 200s find worked best? Right to spec for all? just rear?
If you are 250#s I'd suggest new springs. Stock with just pre load will not give you the bottoming resistance you need. Especially if you want to hit some jumps or go fast on the trail. Also to pre load will not effect the bottoming resistance as much as just adding harshness to the small bumps. This is the main reason we started offering spring kits, they are easy to install pretty inexpensive and work great with stock valving.
