I've used the SPOT satellite personal tracker/signal device for several weeks now, and so far it has been reliable but not flawless. I'm wondering if others have learned any hangfires or dos 'n don'ts about using this thing?
For instance, if I'm lazy and send a message while sheltering beside a large tree, the SPOT signal does not always go thru. This might be because I routinely turn the thing off after its first signal transmission (usually within 60 seconds) rather than leaving it on to repeat the signal. Reliability seems also to drop off beside tall solid objects like chimneys and big boulders, solid things that block a chunk of sky.
Also, is it just me, or does the the message time appear incorrectly in the header of some emails? SPOT apparently uses Greenwich Mean Time (GMT). Even though the msg arrives as directed and is account-logged at the correct time, the correct GMT date/time stamped on the message header is mislabeled, in my case, as Pacific Standard Time (PST). Maybe some software issue with my ISP? I'm not complaining, just trying to fine-tune the method for using this thing.
I have another question.
Anyone know how far you can drop kick SPOT without impairing its functionality?
