I have a 06 900 rmk with 151. Was rideing sun on some trails and after about 50 miles my sled backfired. Temp was running around 130 then went up to about 170. I stoped and checked and my slide kick scratchers had turned and stoped working spraying snow so i fixed them then i never ran over 130 degrees again. Then i was crusing about half throttle and it started to bog I let off and then went to 3/4 throttle and it took off hard and boged again then ran at 1/4 throttle and it seemed normal. 10 miles later I got on it and it did the same thing. It seemed to come out of it by the time i got back to truck. Put a hundred miles on or so total. I cleaned my valves 150 miles ago. I noticed alittle bog at half throttle when i was riding in some deep powder the time before but thought that might be a clutching issue. Had a pretty hard landing begining of the ride on sun. My question is could a wire have shaken loose? Could it be the oil cable? Should i check the throttle body boots? Or do i need to go straight to compresion? Sled has about 500 miles on it.
